Error: No response from vehicle ECU
Old Jan 28, 2009 | 04:36 PM
SLYDOGRACING's Avatar
Question Error: No response from vehicle ECU
I just installed Evo Scan and read my DTC's, well....... after downloading service pack 2, .net Framework and Service Pack 3 it ran like a top. I checked my DTC's it pulled up a 0p500 Vehicle speed sensor so I clicked clear DTC's it did well I clicked data logger it started right up showing all the info and then the check engine light came on again so I went to check the DTC's again and it will not check them anymore or will data log at all it just says
>Initializing Vehicle ECU
>Initializing at 5 baud.....
>waiting for INIT response...
>Error: No response from ECU
Any info would be greatly appreciated
Thanks Guys
Old Jan 28, 2009 | 08:05 PM
I have installed Evo Scan 2.5 on not 1 not 2 but 3 computers and the ECU will not communicate to any of them. I even bought another copy and put in a different serial number for the last computer all 3 do the exact same thing as above
Anyone Please Help
Old Jan 28, 2009 | 08:15 PM
~BoOsTeR~'s Avatar
Is the car cold?
Old Jan 28, 2009 | 09:35 PM
no 65 degrees I'm in Fl
Old Jan 29, 2009 | 04:49 AM
~BoOsTeR~'s Avatar
have you checked the cable for loose connections? check all the pinouts and the slide connector.
Old Jan 29, 2009 | 06:18 AM
Checked all pins connector and plugs look perfect cable is brand new not second hand
Old Jan 29, 2009 | 07:45 PM
~BoOsTeR~'s Avatar
I would at least try idling the car about 5 minutes and then trying to connect. crank the floor heater the whole time.
low ecu voltage and low ecu temps are notorious for making connecting difficult. it's worth a try at least.
Old Jan 29, 2009 | 07:48 PM
~BoOsTeR~'s Avatar
If that doesn't work, put in a support ticket to limitless. (hamish)
Old Jan 30, 2009 | 11:06 AM
Thank You I will definately check into both of those and try it because ecu is still not working saying the same thing
Thanks Again for your help
Old Jan 30, 2009 | 11:24 AM
how do I find the user limitless (hamish) I have searched both with no results
Thanks Again
Old Jan 30, 2009 | 08:05 PM
Slo_crx1's Avatar
I had the same issue with mine as well, but luckily I have a copy of ScanTech that I downloaded from the aktivematrix site. Try it... http://www.aktivematrix.com/forum/viewforum.php?f=15...you need an account though to get it, but it works rather well.
Old Jan 30, 2009 | 08:16 PM
~BoOsTeR~'s Avatar
Thanks Again
go to the limitless website: http://www.limitless.co.nz/evoscan/
http://www.evoscan.org/helpdesk/
Old Jan 31, 2009 | 07:22 PM
Talking
Awesome Thanks Again you guys are the best I got in touch with him and he is going to look into my computer through msn messenger and figure it out
Old Feb 1, 2009 | 08:33 PM
got in touch with Hamish and he actually went inside my computer from New Zealand through Microsoft team viewer and found the problem and is taking care of it as we speak! I would highly recomend anything this guy sells I will always use his stuff from now on!!!! Thanks Again to all that chimed in to help
Old Feb 6, 2009 | 03:47 PM
555R's Avatar
what did he do to fix the issue
i have that same code i cant get rid of and my check engine light stays on
