Gizzmo launch control
Old Feb 16, 2009 | 09:53 AM
yellowevo82's Avatar
How much is involved installing the gizzmo with shift light?
Old Mar 23, 2009 | 11:34 AM
sunnydaze's Avatar
not much at all..
I have the Shift Light and the launch control on my EVO 6 and it works just fine.
If you can install a stereo you can wire this up
Old Mar 30, 2009 | 09:10 PM
8000rpm's Avatar
Originally Posted by sunnydaze
not much at all..
I have an Evo6 is it good? , how much boost do you make with it?
Old Mar 31, 2009 | 01:38 PM
sunnydaze's Avatar
I have a built 2.1L running 26psi on the stock turbo and external wastegate.
The launch RPM is 6100 and I launch @ 13psi steady......
It takes your breath away at launch and rips all 4 tires
