What are the Pros and cons to ECU base boost?
Old Mar 26, 2009 | 07:24 AM
EVO ix 33rd's Avatar
I have a MBC (forge) and am thinking about converting to ECU based boost opinions?
Old Mar 26, 2009 | 07:41 AM
drop24's Avatar
Does ECU controlled boost correct for changes in ambient temperature?
Old Mar 26, 2009 | 07:47 AM
recompile's Avatar
There's a lot, especially if you're really into tweaking the stock ECU. Tephra, mrfred, and others have come out with some amazing improvements for it that allow you to:
  • Hold boost better compared to a MBC
  • Dial in based on load OR based on psi if you have a 3bar MAP
  • Integrate with map switching so you can flick a switch and run different boost levels
  • Integrate with meth failsafe without need for a mac valve
  • (new) dial in different boost profile for each gear
  • (new) auto-adjust based on IAT (so you don't overboost in cold weather)
  • (new) drop boost to wastegate pressure on high knock (configurable to whatever threshold you want)
Not to mention it COMES WITH THE CAR!
As far as cons, the only one is that, unless you're using map switching, you need a laptop to make any changes.
Old Mar 26, 2009 | 08:58 AM
thanks man... so it is actually alil safer then MBC?
Old Mar 29, 2009 | 05:18 AM
recompile's Avatar
Yes, it is safer.
The risk is still there (just like it is with a MBC) that you can set the boost too high and cause problems, but at least using ECU based boost control, it will attempt to auto-correct if you exceed the limits you define.
Austin Kraft
Aug 7, 2012 07:32 PM
catman78
Sep 6, 2011 10:28 AM
VGergo
Apr 10, 2010 02:34 AM
Evolved Monkey
Mar 29, 2006 02:43 PM
