maft wiring question
Old Jul 6, 2009 | 09:27 AM
KleenWhiteMR's Avatar
i bought a used maft from someone on here and it didnt come with the 5 wire harness connector for the stock maf plug. can someone who has one tell me what color wires go to what terminal. also what is the best setting to run if ive made no changes to the tune (3 inch sensor) thanks
Old Dec 9, 2009 | 04:51 AM
crewdawg130's Avatar
the instructions are on there website. Even if you zero everything out, it will change your fueling. ill def be richer up top and who knows what it will do on your trims and idle. you gotto tune it out.
