I had my car tuned by dynoflash.. And then I got my clutch installed.. Jus a question and I know many people ask but how would u know if yur tune is still der or not? Thank yu in advance for the comments.
Tunes don't vanish...it's embedded into the ecu memory. Unless you change the ecu or change the tune then it's the same. You may need to get retuned if you've added mods...
I thought if they disconnect your battery, the memory is erased?
Not sure what sort of parts you're running, but one way to tell is if she drives the same as before.
ur tune is there FOREVER.. if u take ur battery out for 10 years, it will still be there
yeah ur tune doesnt get erased by taking the battery out. only time is changed is when you get it reflashed.
If the car feels different, then something HARDWARE or ENVIRONMENT wise has changed, but tune/software side, it can't change unless reflashed.
