A/F Info
A/F Info
so i just got done installing my new front o2 sensor after it went bad when i installed my new turbo and since then i had also installed a wideband.
When the o2 sensor was still bad it would run anywhere from 10.6-11.9 at idle, and at wot it was at a safe 10.8-11.0
Now that it's fixed, what should my A/F's be at idle?
thanks
thanks
At idle and off boost your a/f ratios should be hovering around 14.7 . When engine braking, it should go very lean but when accelerating it might richen up a little. But in the end as long as your not WOT or in a lot of boost, it should be around trying to reach the 14.7 target.
