Zeitronix ZT-2 question
You can't really directly control boost using the ZT-2, but you can display and log boost at the same time if you use the beige-colored telephone style signal splitter/adapter included in most/all of the kits.
Not sure if JDM / X MAP sensor works, though I imagine any MAP sensor with the same electrical characteristics (see http://www.zeitronix.com/installatio...stallation.htm) would work. Just remember to set the right range in the ZDL Settings --> Hardware Boost Settings menu.
