Obdii
Old Sep 22, 2009 | 07:46 AM
Nelissen's Avatar
Obdii
Wich parameters will be shown by the OBDII on a Evo VIII ??
Eric.
Old Sep 22, 2009 | 08:49 AM
turbolarry's Avatar
It depends on the logger and software. With my cheap palm and free software I only get the basics;
rpm, throttle, timing, air temp, O2's, fuel trims, etc.
http://students.db.erau.edu/~szabafab/stein/
With evoscan ($25 usd) and a laptop I can log all the basics plus things like solinoid duties, knock, injector pulse width, and numerous other things.
http://www.limitless.co.nz/
All of these work through the OBD-II port.
Old Sep 22, 2009 | 11:34 AM
Nelissen's Avatar
What about the boost, can you read that to ?? i will use dashcommand on my carpc embedded in Centrafuse.
Eric.
Old Sep 22, 2009 | 12:52 PM
turbolarry's Avatar
We can't log boost through the OBD-II port without changing the MAP sensor and adding to your ROM;
https://www.evolutionm.net/forums/ec...tructions.html
