Getting strange DTCs from evoscan
This is weird...
Trying to scan for DTCs but wasn't getting anything with OBDII setting and the MUTII EFI setting wasn't connecting...
Tried doing it in MUTIIAYC and this lot came up
Updated: 13:33:35
Diagnostic Codes:12 Val. Power Supply
0xC0 And 0x02 Unknown DTC
26 Speed Sensor
25 Deformed Tyre
24 Rear Left Sensor Open
23 Rear Right Sensor Open
22 Front Left Sensor Open
21 Front Right Sensor Open
0xC1 And 0x01 Unknown DTC
0xC1 And 0x02 Unknown DTC
0xC1 And 0x04 Unknown DTC
41 TPS Open
34 ST-1,2 Short
33 Fixed ST-N High
32 ST-N Short
31 ST Sensor Open
0xC2 And 0x01 Unknown DTC
65 ABS Monitor
0xC2 And 0x04 Unknown DTC
61 Stop Lamp Switch
0xC2 And 0x10 Unknown DTC
56 G Force Sensor (Lateral)
52 G Force Sensor (Stick)
51 G Force Sensor (Straight)
0xC3 And 0x01 Unknown DTC
83 Pump Fail 2
82 Pump Fail 1
81 Pump Relay
0xC3 And 0x10 Unknown DTC
73 Left Direct Valve
72 Right Direct Valve
71 Proportion. Valve
What i don't understand is that I don't have a CEL coming up for anything and the codes aren't clearing...
Now mind you the car was originally converted to run MPH from KMH due to the Japanese 180 speed limit (bought the car this way) so i could expect speed sensor...
But stop light switch? Deformed tyre? Even the Pump fail codes... My ACD/AYC lights don't blink and the system works fine...
is there something possibly I'm doing wrong... i just can;t see all these codes as issues when none of th CEL or ACD or ABS lights show an error...
Updated: 13:33:35
26 Speed Sensor
25 Deformed Tyre
41 TPS Open
34 ST-1,2 Short
33 Fixed ST-N High
32 ST-N Short
31 ST Sensor Open
65 ABS Monitor
61 Stop Lamp Switch
83 Pump Fail 2
82 Pump Fail 1
81 Pump Relay
