Problems with LC-1 Data Logging
Old Apr 15, 2010 | 09:24 PM
firstclaseclips's Avatar
A couple of days ago I installed an LC-1 WB o2 sensor with a G2 AFR gauge in my car. It was working great. Tonight I wanted to try logging to work on my tune but kept getting an error in EvoScan (v2.6 beta 8) saying the com port for the WB was already in use I changed comports around and didn't get anything different. I decided to try to update the firmware with LMProgrammer to see if it made a difference. During up dating, at 70%, it said that it could not access the WB. I tried to update a second time, and the program failed again. I exited the program, but when I tried to open it again, it did not recognize that the LC-1 was switched on. When I started the car, the gauge no longer displayed any AFR reading. I decided to completely recalibrate the LC-1. I did that and installed LogWorks3 and LMprogramer3.37. Recalibrating the LC-1 did not make the gauge read again. So, I tried to updated the firmware with LMprogramer 3.37. It did the update without any errors, but the gauge still doesn't move. I don't want to run the car if the LC-1 isn't running the o2 sensor and wreck it, but it is my daily driver and i need to get to school. If anyone has any ideas about how to fix it or if the sensor will be fine I would appreciate them. Also, I tried to update my evoscan to the full version of 2.6, but none of the links work. Is their website down or something?
