Simple evoscan question
Old Jun 25, 2010 | 05:10 PM
rgar's Avatar
I installed a lc-1 and omni 4-bar map sensor and set them up in the ecu, and entered in the xml in the evoscan data.xml file. They seem to be reading ok, but they are all the way at the bottom of the list in evoscan and all the way out to the right side of the spreadsheet when I log them. If I move them up in the list in evoscan, they stop logging, well at least writing to the log file, they continue to be showing up in evoscan and appear to be logging. Seems to happen even if I just move them up a little bit. I can't think of anything they would be relying on as even if I just move them up over the gps stuff this happens. Any ideas?
*edit* -- If you would like to move the order of the logged items, you can move them around in the data.xml file.
