Evo v stall
Old Jan 25, 2011 | 06:35 AM
MuppE's Avatar
Question Evo v stall
There are a few similar threads, but I didn't find an answer for my problem, so does anyone have a solution?
Stock evo V runs perfect when cold. No problems at all. After shutting down warm, it starts perfect but stalls after 3-5 sec accompanied with the check engine light. The car is stock and all leaks have been checked. Before this the 100amp main fuse was blown for some reason, most likely by a booster connected wrong to the battery when shipped to me from Japan.
So all fuses and leaks checked, works perfect when started cold, stalls when warm. IAC or does someone have some other ideas? camshaft position sensor? Wrong religion on my neighbour?
Thanks for all the replies!
