Making evo show worthy?
Old Mar 11, 2011 | 10:57 AM
Jag14916's Avatar
Question Making evo show worthy?
Hello, i want to take my evo to car shows this year, but i want my car to shine the exterior is flawless to me, i was looking to see if theres recommendations for things under the hood to make things look better, without spending a ton of money.
Thanks for reading
Old Mar 11, 2011 | 11:00 AM
ak47po's Avatar
Thanks for reading
https://www.evolutionm.net/forums/ev...re-thread.html
Old Mar 11, 2011 | 11:18 AM
vanilla2's Avatar
Be sure to throw some lamb doors on that b
Old Mar 12, 2011 | 10:24 AM
turbolarry's Avatar
What really looks best to me is a 350 whp plus Evo and when you pop the hood it looks all stock; a lot of flat black paint, stock heat shields, stock air boxes that have been modified , stock turbos that have been milled out to take the biggest compressor wheels and turbine wheels you can shove in there, splitting the stock rubber intercooler hose and using it to cover after market pipes, stock boost solinoids and lines holding down 25 psi, no A/C, and stock intake and exhaust manifolds that have been extrude honed.
If I see a car like that... Mmmmm! Get's my vote.
Old Mar 20, 2011 | 06:31 PM
josevane13's Avatar
I say just to make it look good u should use belted lines instead of ur stock rubber ones and paint the head on the block and if u can afford it change the spark plug cover its the little things bro
Old Mar 20, 2011 | 09:54 PM
Jag14916's Avatar
I ordered a crbd sparkplug cover, belted lines, ssqv 3 bov, 3 guage a pillar and guages, debating on headers and underlit led's that like phase color, i know there corny but they look sweeeeet. thanks for the input
Old Apr 10, 2011 | 01:38 PM
agiaquinto's Avatar
Less is more!! Simple and clean!! Def hose covers and flat black paint where needed.
Old Apr 10, 2011 | 02:29 PM
bonsuz01's Avatar
Wash the engine so Often, so it will keep clean... To me clean, simple, all match is way to go..
Old Apr 11, 2011 | 06:21 PM
agiaquinto's Avatar
ck this out
https://www.evolutionm.net/forums/ev...ml#post9233421
