Aem ecu knock sensor problem
Old Apr 15, 2011 | 08:59 PM
1_DARKANGEL's Avatar
Ive installed my New AEM EMS. I`ve been told that the Knock 1 raw should give actual Knock readings but it remains at 0.1 - 0.2 volts. The Knock control is enabled and tuned. When I run my car to road tune I hear pinging on the engine and the ECU does nothing! When I look closer at the Knock raw readings it doesnt move either. I pulled up the sensor tab on the Software and there is no Knock sensor window/channel.
I need help with this. If I can`t get reliable knock readings I wont be able to tune accurately and possibly reduce my engine `s life dramaticaly. What am I missing?
