Knock alert idea?
Old Jun 20, 2011 | 06:13 PM
boostnMA's Avatar
Knock alert idea?
You know the beeping sound your car makes when you leave your lights on then shut the car off and open the door? Would it be possible to make this same noise when the engine knocks?
Old Jun 23, 2011 | 04:24 PM
evo8426's Avatar
In the Tephra V7 rom you can set the check engine light to flash when knocking past a certain threshold. The door chime is not controlled by the ecu
