Evo 8 issue*HELP*
Old Aug 17, 2011 | 03:26 PM
rhd-jon's Avatar
Evo 8 issue*HELP*
moved.
Old Aug 17, 2011 | 03:40 PM
4RETECH's Avatar
Can you ohm out the wires to the two plugs and also just double check that you put the wires back on the right cylinders. I only say this because people have messed this up before.
Old Aug 17, 2011 | 03:51 PM
rhd-jon's Avatar
Yea checked that :/
Old Aug 17, 2011 | 03:52 PM
ottoman's Avatar
does it break up based on load? or RPM?
do u have a friend that u can test his coil packs with?
Old Aug 17, 2011 | 03:56 PM
4RETECH's Avatar
What is fuel pressure under load?
Old Aug 17, 2011 | 04:22 PM
rhd-jon's Avatar
i was on 5th gear doing 65mphs on 3500rpms i gave it gas an goes nowhere then 5
seconds later it flys it does it on like 2nd gear and up
Old Aug 18, 2011 | 02:36 AM
ottoman's Avatar
can u check if it's boost related?
drive the car out of boost and varying speeds and rpms and see..
a friend of mine had a similar problem.. when he'd hit boost the car would break up bad..
turned out to be one of the sensors..
