bov advice
bov advice
Okay so im running a hks ssqs, ( came in the car). I hate it, it was vta so i recirculated it and, i'm still havin problems with stalling. Dont get me wrong it runs ten times better, but occasionaly when i throw it in neutral before a red light or a stop sign, it will stall! The tubes not kinked, or anything.
What should i do? i have a hks inlet pipe so idk if other blowoffs fit that flange ( figured others would
) but, i just want the peace of mind knowing my cars runnin 100% no stalling, or idle drop! i'm runnin 23psi btw ideas please!
Somthing i knoticed recently also, was when i mash the pedal and get the rpm's to around 6000 then let off the gas to shift, the car has a mind of its own and redlines for a second as if i didn't take my foot off the gas. I dont know if that has anything to do with the bov ,or what the problem is. But im havin new injectors an cams put in on the 18th. So i'm askin my mechanic whats up with that ,but untill then if you know what my problem is let me know!!!
) but, i just want the peace of mind knowing my cars runnin 100% no stalling, or idle drop! i'm runnin 23psi btw ideas please!Somthing i knoticed recently also, was when i mash the pedal and get the rpm's to around 6000 then let off the gas to shift, the car has a mind of its own and redlines for a second as if i didn't take my foot off the gas. I dont know if that has anything to do with the bov ,or what the problem is. But im havin new injectors an cams put in on the 18th. So i'm askin my mechanic whats up with that ,but untill then if you know what my problem is let me know!!!
My b about the spelling, was typed on my droid, but ill remember to double check my spelling before i post! But on another hand im just waiting to go to the shop and have a pro Look at my car. Hopfuly the rain will hold out for tomorow so i can take a look at everything.
[QUOTE=boostless;9649623]I refuse to read that until you use some kind of damn punctuation. Don't expect much help with a paragraph like that because you're making us work to help
Fixed most of the spelling errors, and puncuated brotha
Nelson999
Jun 19, 2012 08:28 AM
cha951
16
Jul 26, 2007 02:45 PM
