88840016 ROM evoscan Lambda voltage
Hi
I have EVO IX EDM operating rom 88840016. Due to big fuel consumption I would like to check O2 sensor voltage. I used evoscan. Surprisingly evoscan reported very strange numbers. From 0-0.012 V. So, I change O2 sensor. But the same results with new O2 sensor. It seems to be bad formula for 02 voltage. Do you have any solution for that?
Thank you Jaroslav
Thank you Jaroslav
