log boost thru LM-2 to evoscan
Old Oct 24, 2011 | 02:16 PM
evodziobak's Avatar
I wonder is there's a way to log boost thru the LM-2 to evoscan. I was thinking it would be possible to connect the 0-5V output from let's say an aem boost gauge to an analog input of the LM-2 and then log AFR and boost thru the 3840 MTX Series Program Cable to evoscan. Do you guys think that could work? I'm successfully logging AFR to evoscan with the LM-2 now thru the 3840 MTX Series Program Cable.
