Emanage ignition wiring
For those with the ignition working fine on the cars (including those that got it started and working but burnt the coils due to ignition on)..
Did you follow the instructions as per the manual or did you just wired up based on recommendations/workshop wiring ??????
I wired mine up per the instructions and I could never get the car started up .. and here there are guys running with the ignition system for almost a year !!
And yes I'm running 1.36 and I did get the ignition adaptor from Greddy for the CT9A .. nothing works
Try reversing the ignition wires. In some portion of the manual it can get confusing and you may have wired the in and out reversed on the ignition wires. Make sure all your internal jumper settings are set to factory default and the rotary settings are 383.
sadly .. yes .. set pullup/pulldown, 5v and 12v .. didn't work ..
no codes on the emanage ..
sigh .. even got the emanage adaptor for the emanage ..didn't work too ..
how many guys here running with the ignition without problems ??
Mine is ok, even survived 45 minutes with the key on/engine off last fall.
Just a thought here, if there is a value in the very first cell would that cause the e-manage to try and send a signal to the coil (that's not firing) causing it to overheat and short out?
