biss screw adjustment settings question
Old Jan 10, 2012 | 07:05 AM
Can Of Rockstar's Avatar
Hi guys, so I had a problem with my iac recently and was trying to get to the bottom of it. The car kept dying on me and all that, and I figured it was my iac, but my dad wanted to put a band aid on it and opened up the throttle with the biss screw..... I know, bad idea, so now i got my new iac and I want to adjust the biss screw back into original position which is hard. Please help me out here, if you know what the distance from the screw to the edge of the hole that its in by using a caliper that would be awesome. thanks.
Old Jan 10, 2012 | 07:08 AM
shrtstuff89's Avatar
I believe its called evoscan, but you need to activate SAS mode then adjust the Biss accordingly. Loosen it to raise the idle, tighten it to bring the rpm lower
Old Jan 11, 2012 | 09:36 AM
that would be great if i had the proper tools, but im on a budget right now, and there is a way to tune it without using the evoscan. i just need someone who has a depth measuring caliper to measure the depth of the stock screw setting and tell me what it is.
nytalonTSi
Jan 8, 2019 06:57 AM
Raceghost
Jun 10, 2016 11:28 PM
steven121
Jul 4, 2014 10:29 PM
evol evo
Jun 30, 2014 07:09 PM
prowakeskater
Oct 13, 2012 10:17 AM
