FIC 1650 Cons??
FIC 1650 Cons??
I’m in the process of a 2.4 gt35r build, I plan on running just pump gas and I have been looking at upgrading my injectors to 1450 possible 1650.. for those out there running FIC 1650 I was do you have any issues running them, I have been told that injectors larger then 1450s tend to have issues.. Scaling, idle, ect ect.. any information would be helpful thanks
No. On gasoline you arent going to max the 1450s, especially 91 octane. For reference, 1000s and one 255 will support 600whp if octane isnt a consideration. A double pumper and 1050s (which flow like a 1200) should be more than enough.
I have them. They are a pain in the *** to scale. I still change things quite frequently. I'm running a full blown twin -10 feed -8 return with the 1650's and 37psi base fuel pressure. 30psi on a 37R and I was affraid I'd run out of fuel. First pass I logged 9.9:1 afrs. That is the low limit to my zeitronics so it was probably much richer. I'm stepping down to 1000's or 1200's. These things are way overkill man.
silverflyer
89
Aug 23, 2017 08:50 AM
mrfred
Dec 27, 2016 09:26 PM
jos
Jun 17, 2016 03:48 PM
whotippedmycow
May 19, 2016 11:39 AM
OneCrzyEvo21
14
Aug 2, 2010 07:15 PM
