Help! Loosing power
Old Feb 17, 2013 | 01:20 PM
Fishd0's Avatar
Help! Loosing power
The car pulls goos til about 5300to rpm then falls flat. Has turbo back exhaust, k&n intake, intercooler hard pipe kit, hks bov, 720 cc injectors.
Old Feb 17, 2013 | 01:25 PM
ReaperX's Avatar
I would first do a boost leak test.
Old Feb 17, 2013 | 02:32 PM
Fishd0's Avatar
Got the codes pulled. Got a few of em: egr, tps, radom misfire, o2 sensor bank 1 sensor 2 high voltage, manifold differintial pressure sensir
Old Feb 17, 2013 | 09:17 PM
Fishd0's Avatar
I will build the mechanism to test for that tomorrow. Any other recomendations will be greatly aprriciated as i am new to Evo's
Old Feb 18, 2013 | 08:38 AM
Fishd0's Avatar
Checked for leaks and found none. Anyone else have a suggestion?
Old Feb 18, 2013 | 09:26 PM
Fishd0's Avatar
Figured out that the stock boost solenoid wasnt hooked up, has tons more power but still looses power after 5000 rpms. Like the fuel cut hits. Please some one help
Old Feb 19, 2013 | 01:09 AM
tscompusa's Avatar
sounds like boost cut then yes. you must go into the rom and raise the % higher to avoid the boost cut. the other way is raise the delay timer really high, but that is the irresponsible way and i do not agree with just eliminating a safety feature when there is absolutely no reason to do so.
even on high powered vehicles, you can utilize x2 tables for double the % resolution.
Old Feb 19, 2013 | 06:08 PM
Fishd0's Avatar
Do i need something like an AEM EMS or can i just use some flashing software and a laptop
Old Feb 19, 2013 | 06:45 PM
Ev0ikon's Avatar
Read.
Old Feb 19, 2013 | 06:49 PM
Ev0ikon's Avatar
Talking
Originally Posted by Fishd0
hks bov
nono
Old Feb 19, 2013 | 07:06 PM
Fishd0's Avatar
What?
Old Feb 19, 2013 | 07:16 PM
Ev0ikon's Avatar
What?
That valve doesn't work well on an Evo. It's fine on other cars though.
Old Feb 19, 2013 | 08:21 PM
Fishd0's Avatar
What about tuning?
Old Feb 20, 2013 | 10:57 AM
will1311's Avatar
have the stock ecu tuned.
Old Feb 20, 2013 | 01:19 PM
Ev0ikon's Avatar
What about tuning?
"Get remote tuned at: TSCOMPTUNED"
But I gather from your recent posts you will need to get your hardware sorted out first. Make sure all are mechanically sound before you spend money tuning it.
