Building an ignition cut device: looking for input
Old Apr 8, 2013 | 07:50 PM
211Ratsbud's Avatar
I would like to build an ignition cut device. Starting with wasted spark. I think I could use a solid state relay in the ecu to coil line and just trigger the relay.(Arduino ) The ground in all cases will be the sas pin . With a simple array [0,255] using an analog dial, is it ideal to control relay frequency like this?
Or should I be cutting the power that energizes te coil
03ozrazing
Lancer Troubleshooting
Feb 14, 2017 04:01 PM
Mike W
84
Aug 19, 2016 08:36 AM
240Z TwinTurbo
Apr 25, 2013 04:06 AM
hotstix
19
Aug 16, 2011 09:51 PM
