AFR calibration and setup
Old May 23, 2013 | 04:00 PM
PL_MR's Avatar
Hi,
I would like to confirm what I think from what I have read on forum for AFR setup...
I install a WBO2 and I see that I running 14.2 at idle(stock map), I tought I would be more at 14.7. Is it normal or when I have done the calibration, I have mist something?
I think calibration was good because it read 21.9 when was not in the exhaust at ''free air'' but...
I have a Intake, I know this can altered the AFR.
And from what I read, I can run like 16.2 for fuel economy and the zone of like 500-3500rpm and 0%-70%load?
And I target 12.5 for best torque (something like until 4000rpm at high load) and I taper it down to 11.5 at 7000rpm?
(I have full TBE, Injen intake and lower/upper piping, o2housing, grimspeed3port and 4bar map for direct boost control and boosting to 25 psi tapering to 21 at redline, modified MIVEC and timing map, on tephra V7)
Thanks!
nj1266
Jan 25, 2026 01:43 AM
nutrulz
AEM EMS
Aug 18, 2008 01:49 AM
tkklemann
Feb 7, 2008 11:52 AM
recompile
Aug 29, 2007 08:45 AM
fbikawi
Mar 12, 2007 09:50 PM
