What the different between Hks Ecu with any Ecu
Nothing wrong with HKS... I wont be able to answer your question as I don't have much knowledge as to what you are asking, but I can say a lot of people from Australia use Haltech. Seeing how you are from NZ, maybe you can get more info about Haltech over HKS in your local area.
But I will say stock ecu tuning is favored more over stand alone depending on the extent of your build.
AFAIK fcon works in parallel with the stock ecu its
a piggy bank than a ecu replacement,
also v3 does not handle mivec , v4 will..
my humble opinion is for the amount of money that fcon cost
go buy a decent ecu instead (f.e motec m800 oem
Michael.
)Michael.
Bro get the link g4 plug and play ecu it just plugs in where the old ecu went super quick just needs dyno tune. Link is the number 1 ecu sold in nz plus its nz made in chch. plus the new G4 plus ecu Bluetooths to your iphone or ipad so you get all the data you need. That's what im pumping in my 7 go's mean.
FS[SouthEast]: Evo 9 ECU
hutch959
Dec 30, 2016 06:40 PM
