E-Manage Screenshots/Software
Old Feb 28, 2004 | 05:13 PM
feldguy's Avatar
Ok, so I've been thinking about integrating a laptop (as I said in another post) What I neglected to ask was, what monitoring capabilities does the e-manage software have in real time? Tach? EGT? Duty cycles? I can't find any info on it anywhere, just all general specs. I'd like to use the Profec as a boost gauge, the e-manage as my EGT and whatever else I can tap into. Also, I will be using the AEM wideband UEGO controller to tune as well. Any info is appreciated. Thanks
Old Mar 1, 2004 | 06:41 PM
992gnt's Avatar
Next time I have the emanage hooked up I'll save some screenshots from the Real Time display - nevermind, here's a saved one (sorry for the size).
You could use a 0-5v egt wired into the pressure sensor port on the emanage, but it will only show you voltage. I don't think you can build a table to turn it into degrees. FYI, I'm using the TechEdge wbo2 which allows 2 additional 0-5v inputs and 2 thermocouple inputs. One of the users has created a really nice logger gui for it and you can put in your own conversion tables to log virtually any 0-5v device.
