Idle issues out of nowhere
Old Jan 14, 2014 | 12:35 PM
-Hum-'s Avatar
Hi everyone,
I just started having some trouble with my idle quality. This happens on all tunes the car has been on, so I don't think its tune related. This is also across fuel from 5 different stations, and both 91 and 93 octane. Pump install was recent, but this issue did not crop up immediately when the pump was installed, but a week after.
What is going on is that when cold, idle AFRs are floating from 14.5 to 15.2 ish. That's fine with me. Once it warms up ( i think I can pinpoint right on the temp gauge when it goes to closed loop) it will fluctuate from 12.5 to 17 on my UEGO. It seems like these are real AFRs, as when I try to start rolling casually, it will bog when rich, and when i see it go lean, I feel it stumble/possibly misfire a bit. Fueling when under load seems normal along with cold idle, which leads me to believe it is a closed loop problem.
Any ideas?
Plugs are stock gapped to .022
Boost leak test good up to 30 psi (didn't check higher)
Mods pertinent to issue:
Perrin intake
Stock cut up airbox
3 port
3 inch turboback
Walbro 255
Racelite flywheel and HD 6 puck (ugh)
I will post cold and warm logs tonight. My initial inclination is ISCV or NB o2 going bad... however I simply don't have a ton of experience with Evos. My ISCV idea is backed by the fact that I have high load shift throttle hang/rpm spikes, which apparently can be cured by ISCV map changes.
Any help appreciated!
Old Jan 15, 2014 | 08:45 AM
Biggiesacks's Avatar
My guess would be Narrowband issues. What do your LTFT Low + STFT's look like? When cold it is not running in closed loop which is why you are seeing stable numbers there. It sounds like your problem is when closed loop kicks in, which to me would point to the narrowband 02 sensor.
Old Jan 16, 2014 | 12:22 PM
-Hum-'s Avatar
LTFT Low is at about 10, and short term just climbs... I'm replacing the NB o2 tonight.
I double checked my leak checking with a can of carb cleaner last night, and couldn't find any issues. Pretty well convinced the NB is the issue.
Old Mar 12, 2015 | 03:39 PM
vmrevo9's Avatar
Veteran: Air Force
Have you been able to figure this out?
Old Mar 26, 2015 | 08:44 PM
-Hum-'s Avatar
Yes I have. NB O2 was replaced and all was well. Trims now even on E85 are around 1%
mrfred
Aug 1, 2022 06:05 AM
simple_lancer
Oct 14, 2020 02:18 AM
Raceghost
Aug 10, 2018 10:39 PM
Rom
Aug 16, 2017 01:18 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
