WHP expected
Old Mar 24, 2004 | 08:15 PM
batty's Avatar
WHP expected
Lets say you have mods such as Walboro Fuel Pump and Turboback exhaust. If you bought the UTEC with these mods what numbers can be expected.
Old Mar 25, 2004 | 12:32 PM
nmyeti's Avatar
On our dyno I would expect around 290-300whp.
Old Mar 25, 2004 | 01:53 PM
PDXEvo's Avatar
Really? 290 to 300 WHP just from Fuel pump and Turbo Back with no boost controller? What dyno are you guys using Nathan?
Old Mar 25, 2004 | 01:58 PM
TDC's Avatar
TDC
In Timeout
Dynapac without the wheels. Expect about 275 at Turbotrix, 285 at Pruven
Old Mar 25, 2004 | 02:09 PM
nmyeti's Avatar
The UTEC is a boost controller. Don't forget that we would be turning it up to 20psi with the UTEC.
For what it's worth, we hit just over 300whp with this setup on Altered Atmosphere's dyno. If you look at the Altered Atmosphere dyno day threads, you’d think that one reads low.
-Nathan
www.turboxs.com
Old Mar 27, 2004 | 12:27 PM
Shahul X's Avatar
thats awesome...I did about 275 on A. Atomspheres dyno with a boost controller , Afc and TB exhaust, so the UTEC definetly helps!!!
-shahul
Old Mar 28, 2004 | 09:08 AM
prostockCRX's Avatar
You should also take in to account that no two cars are exactly alike. On our dyno i've seen as low as 220whp and as high as 250whp from evo's in bone stock trim. So it's difficult to say for sure what you will see if you add a utec, all i can say for sure is that you will see a gain if you have someone competent behind the laptop.
