[HELP!!!] ABC installation
Old Mar 26, 2004 | 05:53 PM
whiterexman's Avatar
Old Mar 26, 2004 | 06:26 PM
nmyeti's Avatar
You can either put the ABC in the stock line or replace the line with the supplied extra 4mm and install the ABC in the new line.
Without installing the ABC at all you'll peak out at about stock boost.
With the ABC in the line you can increase boost pressure a little bit.
With the 4mm line and the ABC installed you can get quite a bit more boost pressure.
-Nathan
www.turboxs.com
Old Mar 26, 2004 | 06:30 PM
