Car leaning up at end of pull.. Not sure why. Need advice
Old Apr 3, 2016 | 03:47 PM
Seidelly's Avatar
Need some advice on a fuel issue I am having.. My current setup is as follows..
ID 2000's
Buschur DP 255's
-8AN Feed
Stock feed line in place of stock return line.
Stock fuel rail
Stock FPR
I have ruled out everything below.
- Fuel pumps both replaced x2 + new filters
- Inline fuel filter
- FPR
- Wideband Sensor
It only occurs after 28PSI; its leaning up towards the end of the pull.
Any ideas?
Old Apr 3, 2016 | 03:49 PM
Seidelly's Avatar
Attachment 326895
ridenrunwv's Avatar
Just posted in your dyno thread. Are you currently tuning this car or was it running correctly and then this started occurring?
Seems like you're only running one pump but I don't think one 255 could keep you the AFR you have as long as you kept it before leaning out.
Old Apr 4, 2016 | 10:26 AM
Seidelly's Avatar
Currently tuning the car; none of the fuel system was installed prior to saturday.
That did cross my mind but its not possible that I would be making this much power & holding 11~ afr .
If boost is lowered to 28PSI or so, the problem reduces itself greatly.
Its obvious its not getting enough fuel but I dont know why. Everything has been replaced.
Teal2nnr
Oct 30, 2012 10:29 AM
Z_Lancer_Man
Lancer Aftermarket Forced Induction Tech
Aug 1, 2006 04:55 PM
Ralli04Art
Dec 15, 2005 06:24 AM
