Evo 6 harness to OBD2 Plug Wiring Help
Old Feb 21, 2018 | 01:31 PM
markseb44's Avatar
Hi. Im new to this so I hope I don't stuff it up.
I have a Evo4 with a TM 6.5 transplant. When they did this, it seems they removed the ODB2 connector from the harness, as I can not find it anywhere!
I would like to solder in a connector, so I can utilise an ELM??? bluetooth connection to get data from the ECU. I found a few months ago in a forum, advice on which pin from the ecu to which pin on the OBD2 connector, and have now lost that info And I can't seem to find it anywhere now.
I have hopefully attached an image below that is the correct ecu pinout diagram....and would appreciate any info on which pins i need to connect where on the OBD2 plug.
Thanks in advance
fireroasted
18
Nov 2, 2015 06:37 AM
4g94
Jan 17, 2011 06:58 AM
leecavturbo
Nov 16, 2008 06:52 PM
GTS_666
Canadian Forum
Jun 20, 2008 08:32 PM
PiNG
Apr 27, 2008 11:00 PM
