HELP!!! New build evo 8 2.4 cranks won’t start tried everything
Old Mar 17, 2018 | 09:21 AM
CurseDSM's Avatar
I would say kill switch from the alarm. Get rid of the alarm and it should start. Alarms will mess with ignition causing no spark.
Old Mar 17, 2018 | 09:50 AM
Biggiesacks's Avatar
Originally Posted by harrison.little
immobilizer disabled went into the lower timing cover and crank plate and sensor all look fine. I ordered a new cam angle sensor but shouldn’t it be showing a code if it were that? I also have an aftermarket alarm system could that be causing it
depends on how the alarm is installed. A typical install would just be to interrupt the starter. If the installer knew what he/she was doing they could have interrupted the ignition circuit. You would know if that was the case because you wouldn't get voltage at the ignition coil harness.
Old Mar 19, 2018 | 02:34 PM
harrison.little's Avatar
Figured it out thanks for the help. One of the 3 prints on the cam angle sensor was bent up and wasn’t connecting into the sensor correctly.
Old Mar 19, 2018 | 03:21 PM
Never mind reinstalled sensor after straightening it out and still nothing, have no idea what to do now
Old Mar 19, 2018 | 04:43 PM
Siluck2's Avatar
I’m almost willing to put money in that you may have the crank sensor installed incorrectly. I did the same thing and thought it was correct but it wasn’t. I’d check that if you haven’t.
Old Mar 19, 2018 | 06:19 PM
As far as I can tell it is correctly in what do you mean by installing it correctly. It is torqued to the right spec and defiantly on the crank plate
Old Mar 19, 2018 | 07:28 PM
2006EvoIXer's Avatar
Only way I can think of to be incorrectly installed is if the plate was flipped over. But that would be easy to see it's wrong.
FF to 6:55 mark...
Old Mar 19, 2018 | 10:17 PM
Siluck2's Avatar
You can also have the sensor flipped too.
Old Mar 19, 2018 | 10:27 PM
will plate go through sensor if sensor was flipped?
Old Mar 20, 2018 | 11:57 AM
Siluck2's Avatar
Can’t remember if it will or not. But I had the sensor flipped on mine, so that’s how I know it’s possible.
Old Mar 20, 2018 | 12:14 PM
I better check mine because my sensor could be flipped. That would explain why the plate was making contact on the inside.
Old Mar 20, 2018 | 02:50 PM
Siluck2's Avatar
if your sensor is flipped it wouldn’t trigger...
Old Mar 22, 2018 | 04:25 PM
Here is a picture of my crank plate and crank sensor I don’t see anything wrong with it sensor and plate are both the right way as I can see
Old Mar 23, 2018 | 01:37 AM
CurseDSM's Avatar
How is your timing belt installed? What belt did you use? What marks did you use to assure everything was straight when the belt was put on?
Old Mar 23, 2018 | 07:12 AM
timing belt got installed by a buddy who says he’s timed a 2.4 evo before. It’s the timing belt off of the galant I’m pretty sure I got the part number from a shop that did a previous build on a 2.4. I am thinking my timing has to be off the one mark on the balancing shaft doesn’t line up with the timing mark on the crank plate.
