Question about haltech elite
Old Jul 21, 2018 | 05:36 AM
tauro91's Avatar
Evo 9 with haltech elite 2000 and Evo 9 plug and play harness adapter. My question is, do I run the i/O report and wire these sensors to unused analog inputs or do I splice into my stock engine harness...? For example for the boost solenoid, ait, and map I cut oem connector and spliced into them but idk that's the best way. Any input on this??
My aftermarket sensors are
AEM map sensor
AEM oil press
AEM pressure for fpr fuel datalog
Haltech flex fuel
AEM IAT sensor
Haltech 3 port boost solenoid
Old Jul 22, 2018 | 09:50 AM
CurseDSM's Avatar
AEM map sensor
AEM oil press
Haltech flex fuel
AEM IAT sensor
Haltech should pick all that up. Everything you have mentioned you have to go in and configure and tell the haltech what and where it is located with what wires its pretty easy but a little time consuming. Here is a vid of how it can be set up
Old Nov 5, 2018 | 10:10 PM
Fox_IX's Avatar
Yes, that's how I did it. All of my aftermarket sensors are on additional AVIs. The only exception are IAT and MAP, these both use the factory wires in my plug n play harness.
You can also contact Haltech and they'll set up a base map for your setup(or at least they used to).
I'm running an Elite 1500, feel free to shoot me any questions.
Old Nov 24, 2019 | 11:25 AM
mines5's Avatar
Hello guys,
Digging up this thread, i am about to get haltech elite 1500 for my Evo 8.
1- The PC Logging option doesnt show in the ESP software. Do i have to connect to the ECU to get any option in the data manager ?
2- I can not see the Short pulse width adder table in the evo 8 pnp base map.
tauro91
Jul 21, 2018 12:33 PM
3bar_dc2
12
Jun 19, 2015 07:15 AM
senson
Sep 1, 2009 02:18 PM
senson
Mar 27, 2009 06:16 AM
joosdawg
Jun 17, 2007 12:13 PM
