AIT and Ethanol Sensor in to MAF Plug (Haltech)
Old May 5, 2019 | 09:19 PM
xRoguex's Avatar
Short version, the car will never run on a MAF again.
Haltech Elite 1500
Is there any reason I cant wire both my AIT and my E Sensor in to the MAF plug as follows:
AIT - In to Pin 5(Ground) and 6 (AIT Signal)
E Sensor - Pin 3 (MAF Signal), Pin 4 (12 volt) ) and Pin 5 (Ground)
****EDIT****
Confirmed by haltech, this will work, and minimizes wiring!
Old May 6, 2019 | 10:37 AM
Lumpy Sticks's Avatar
5 Year Member
That is honestly a really good idea. Wish I would have done it that way but too late now. I ran a fuel PSI sensor at the same time so I guess I was stuck running extra wires anyways.
Old May 6, 2019 | 10:07 PM
xRoguex's Avatar
Depending on sensor type - send the psi signal back through stock Baro sensor?
I'm just a huge fan of keeping it simple...
Old May 7, 2019 | 02:31 PM
xRoguex's Avatar
In case anyone hits up this thread down the line - the way referenced in post 1, will work, both confirmed by Haltech, and then tested by me.
Car runs!
Now the fun begins
Old May 8, 2019 | 12:25 PM
mines5's Avatar
Car runs!
Now the fun begins
Can you share your Base map here?
Old May 8, 2019 | 07:29 PM
xRoguex's Avatar
Its getting tuned over the next week - but the map will be created by a shop, so I cannot post it.
