Need help!
Old Jul 29, 2022 | 05:04 PM
timasse's Avatar
Need help!
Hello,
I’m having some troubles with my evo 9.
When the weather is hot, the car doesn’t run well on idle. And it get worse when the A/C is on. It can actually stall when I do some pulls or push on gaz pedal quick. The AFR seems way off sometimes.
Got some mods: Air intake, turbo, exhaust, intercooler piping, gs2 cam.
I reisntalled evoscan after years. Not sure I logged everything correctly.
Anyone can guide me into this?
Thanks
Old Aug 23, 2022 | 06:44 AM
P0301's Avatar
Fuel trims suggest it's running rich. That would be consistent with the fact that it gets worse at higher temperatures.
I notice there's no MAF sensor data in the logs. If you can configure evoscan to read that data, and it reads too high (>2g/s at idle?), then that could be the source of your problem.
Otherwise check air filter, clean injectors, the usual.
EDDY PRIME
Nov 17, 2020 12:43 PM
8ASTI
For Sale - Cars For Sale
24
Jul 8, 2009 06:56 AM
Evogelion
Northwest Region
12
Dec 5, 2006 04:35 PM
initialDRacer
Mid-Atlantic Region
Apr 22, 2005 05:13 PM
