Fuel pump relay constantly switching
Old Jul 6, 2024 | 04:19 AM
dav7's Avatar
As soon as I hit 2300rpm in my Evo VII the fuel pump relay on the firewall starts rapidly switching on/off and continues to do so till about 3500rpm
Always happens at exactly 2300rpm, and stops as soon as the revs climb
What would cause this? My understand is the relay on the firewall is fuel pressure activated?
Is it more likely to be a faulty relay? Or a fuel pressure issue, maybe a dying fuel pump or faulty regulator?
Old Jul 6, 2024 | 06:35 AM
Kevin.'s Avatar
Start with the relays. Should be two speed fuel pump relays, one for cruise, one for WOT. ECU may be switching fuel maps at that RPM and the relay is failing.
Old Jul 7, 2024 | 04:25 AM
dav7's Avatar
Is the relay triggered by the AFM?
There is no check engine light, but I thought I'd just check engine codes to see what I got
And I've got
P0110 Intake air temperature circuit malfunction
P0100 Volume airflow circuit malfunction
P0105 Barometric pressure circuit malfunction
Could a bad MAF sensor cause all those?
Old Jul 12, 2024 | 02:02 AM
dav7's Avatar
Couldn't find anyone local that had a OEM fuel pump relay in stock. Paid $100 to have one air freighted to me. Starts clicking immediately, just constantly clicking on and off rapidly soon as I get around 2100rpm - 2300rpm
I've ordered a new MAF. Hopefully that fixes it or that's a lot of money to get no where
Old Jul 18, 2024 | 02:45 PM
dav7's Avatar
brand new MAF and brand new OEM relay now
still no bueno
error codes are gone, and car idles a bit smoother. But relay still clicking constantly and so loud I can hear it over the stereo
Old Jul 28, 2024 | 03:20 AM
Geforce_EvoIX's Avatar
maybe a loose ground or bad wire on the fuel pump thats not allowing full connection all the time? mine was corroded and nearly broken in half.
does it happen if you give throttle in neutral or only when youre driving and under load?
how your battery, if not 90% full you can have problems, ive had mine read 12v but would drop to 10v when starting.
youre 100% sure its the fuel pump too? what happenedto your afr at that 2300 spot?
check your throttle position sensor and the IACV too
sadat_evo8
Jul 29, 2023 08:50 PM
Xearo
Sep 16, 2012 02:04 PM
Boostfiend
Jun 21, 2011 07:33 PM
dustin03
AEM EMS
Apr 8, 2007 07:37 PM
