UTEC Dashboard for PocketPC
Old May 25, 2004 | 04:20 PM
MalibuJack's Avatar
Hey guys.. Just wanted to announce I'll be releasing a dashboard for Windows CE and PocketPC 2000+ (Haven't tried it in CE.NET or PPC2004)
The realtime dashboard isn't super useful, but it has peak holds for several parameters, and a peak hold for the TXS Tuner (it grabs the richest reading at RPM and the leanest reading at RPM, but only under load)
It does have one INCREDIBLY useful feature.. not requiring a full PC go grab logs that can easily be imported into DataLogLab's software (www.dataloglab.com)..
I have some UI modifications to make, and add some configuration parameters (like com port, save directory, etc...) that are saved and restored every time the app is run.. also making the peaks and triggers user customizable
(A trigger can make a noise, or flash the screen, or whatnot based on any of the log data) I've already used it for changing the screen background color at RPM's for a shift light sort of thing.
I'll also be adding some horsepower calculations "Dyno-Run" features in future versions..
