running catless w/ UTEC?
Old Jul 21, 2004 | 01:48 PM
jasonc32amg's Avatar
Can the UTEC turn off the CEL when running catless? I had an Excede on my old Evo and didn't like the fact that I could not address that issue with it...
Old Jul 21, 2004 | 01:55 PM
SoR's Avatar
SoR
You can turn off CEL if you want to.
Old Jul 21, 2004 | 01:56 PM
Excellent... you access it through a laptop on the UTEC?
Old Jul 21, 2004 | 01:59 PM
SoR's Avatar
SoR
Exactly, however when you turn it off, you will not know if anything's really wrong with your engine.
But, as far as I remember, the problems will still be logged in the ECU.
Old Jul 21, 2004 | 02:01 PM
ohhh, so you are not just eliminating the particular signal prompting the CEL, but disabling the CEL itself? I don't understand why there isn't a method to do this the right way. On my cobra I was able to turn off the cat sensor...
Old Jul 21, 2004 | 02:32 PM
MalibuJack's Avatar
No, I did make a suggestion in another "feature list" thread for requesting an secondary O2 simulator feature so the ECU would no longer throw the code.. It should be one of those wish list threads somewhere around here.. You can get a CEL eliminator adapter, or an electronic device that you can use.. there out there, but make a request for this as a feature, if there's enough demand, I'm sure they'll try to implement it if they can.
You can turn off the CEL indicator but that turns the light off.. not eliminates the code, the problem is you won't see other indicators that would trigger the CEL either.
Old Jul 21, 2004 | 03:51 PM
thanks... that is exactly what I want to be able to do...going catless made a big difference on my last evo
Old Jul 21, 2004 | 03:58 PM
MalibuJack's Avatar
My experience has been it had a very negligable effect on performance running without the cat.. so I chose to keep the car legal and not risk the fines or whatnot.. I do have a little green in my blood anyway so I prefer to keep my car running clean. I think my car made a whopping 5whp difference between a performance catalytic converter and a straight pipe.. not a big enough difference for me to keep it off. Now the difference between stock and a cat delete pipe, thats night and day..
Old Jul 21, 2004 | 05:06 PM
I respect that...thanks for the info
