SAFC II default settings for EVO VIII...
Old Aug 8, 2004 | 11:21 PM
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
What's up guys! Well I finally installed my SAFC II including a Apex'i turbo timer. After putting things back together and reconnecting the battery, I turn the ignition on to notice my "Service Engine Soon" was lit. My question is, is this normal when first time hooking the SAFC II? Or could it be some faulty wiring? Another thing, I need the default settings for my car set. I know its 4 cylinders but don't have a clue of what to set for the following:
sensor type
throttle sensor type
etc.
If anyone can provide default setup for non tuning purposes I'd greatly appreciate it!
Old Aug 11, 2004 | 12:54 PM
lanevo4g63's Avatar
hey
i did the same **** and ended up taking the **** out because it was beyond messing up. We tried all different type of settings and after about 5 months i took it out. take it out or you'll regret it.
Old Aug 11, 2004 | 03:13 PM
Whooopasss's Avatar
Registered User
read here for initial instal
http://www.evotuners.net/forums/show...?&threadid=111
Old Aug 11, 2004 | 03:14 PM
Whooopasss's Avatar
Registered User
from that site "Initial setup of your AFC-II may seem bewildering at first, but I assure you that it is easier than you ever thought. To begin turn the ignition to the on position to power up the AFC-II, once the splash screen has cleared you should see a couple of options on the screen. The first option is to access the monitoring functions of the AFC-II and is aptly named [monitor], the second option is where you will make all of the fuel adjustments and is named [setting], and the final option is named [etc.] and is where you will find all of the vehicle specific setup options. We will start with the [etc] menu by scrolling down to highlight it and pushing left on the joystick in the center of the control knob to advance to the next menu. Highlight the [sensor type] option in this menu and press the joystick to the left once again, scroll down with the joystick until [karman] is highlighted, now press in on the joystick to bring up a cross shaped sub-menu. Press the joystick to the left to illuminate [Pr] and push in once again to go back one menu, once you can see [sensor type] and [car select] again scroll down to highlight [car select] and push right to advance. Here you should see either ¡§4 cyl¡¨ or ¡§6 cyl¡¨ and an arrow, twisting the control knob counter clockwise will decrease the number of cylinders. We want the number of cylinders to be set to ¡§4 cyl¡¨, once this is complete push the joystick to the right to illuminate the arrow. Twist the control knob clockwise until the arrow points up and to the right, now press the joystick to the left to back up through the menus until you are back at the main menu.
Old Aug 12, 2004 | 12:30 PM
Technoz's Avatar
did you solder it or just crimp it. If you didn't solder, that may be a problem. Not sure about the CEL, I still have mine on from my exhaust
Old Aug 12, 2004 | 12:38 PM
Whooopasss's Avatar
Registered User
always solder...
when I installed my exhaust and down pipe, never had a cel.. then installed the AFC, never had a cel.. for your exhaust, check your 02 connector or wires..
Old Aug 12, 2004 | 12:43 PM
93civEJ1's Avatar
Yeah ive had my AFCII on forever now, and not one single CEL.... wiring and setup was simple as well, if you just read the manual you should be fine. Also I recommend soldering. Mine works fine %100 ..NO CEL.
Old Aug 13, 2004 | 09:09 AM
Technoz's Avatar
If you mean me, I have the cel because I have a test pipe and no o2 sim, so it's not a matter of the wiring
93civEJ1's Avatar
I have the UR test pipe, and no cel...which do you have??
Old Aug 13, 2004 | 02:44 PM
Technoz's Avatar
Buschur
Old Aug 17, 2004 | 08:48 AM
Pino's Evo's Avatar
So how do you get rid of the Service light? mine just got installed and I'm tired of ressetting my battery. Also If you guys don't mind I'd like to know what settings you guys have on HI throttle. thanks
Old Aug 17, 2004 | 10:28 AM
Technoz's Avatar
no idea on the CEL, but my settings are +1 or 2 around 3000 and from there go from -1 to -11 up to 7400 pretty much linearly.
Old Aug 19, 2004 | 09:16 AM
Pino's Evo's Avatar
Wow, (-11) is'nt that a little low? I was told to keep the % at around +,- 5 Until I get it dyno'd. Oh yeah, what is your throttle pecentage on "lo" and HI"?
Old Aug 19, 2004 | 09:22 AM
Whooopasss's Avatar
Registered User
I got mine set from +4 at 3500 to 12 at 7000 RPM..
Old Aug 19, 2004 | 03:00 PM
Technoz's Avatar
it might be low, but so far so good, dunno. I read all the threads I could and kinda took an average of all the numbers I found. low throttle is 55 and high is 70 I think? not positive.
