US Instructions for Power FC D-Jetro
Originally Posted by Guru
I would need to have the car here to figure it out for you.
If your Power FC is for an Evo 7, you have to change 2 wires in the Ecu connector,
you have to switch the position of pin 8-22.
After that, if you have installed the map sensor and the air temperatur sensor, it should work.
Originally Posted by GTVEVO
Sorry but the unit is the wrong model and doesn't work don't to begin with so no worries.
Even if it was for an Evo 7 it still would work. It worked for my set-up, which is WAY different than yours. Guru did little tuning on my car and had it working no problem. You couldn't expect to just plug this thing in and expect it to make the power as it did on my Evo. I'm running a 35R, 770 injectors, Magnus SMIM, custom piping, 272 cams, and a ton of other stuff that all need tuned in differently. Like I said before, send me the freight and I'll send it back to you. Until then I'll hold it in my inventory until you let me know otherwise.
Serial No. PFC EVO7D 020-0059
Product number (number on box). 414-M008
Fas4dr
21
Jul 28, 2016 04:22 PM
