Evo Utec Ver. 1.6 Pre-Release Party
Old Sep 22, 2004 | 06:56 AM
Imprezd's Avatar
The moment is so close, I am sure you guys can taste it.
We have the final version for release, we just need to update the instruction manual and then I can point you all to the Evo Utec Update Site.
The most noticeable software interface change is the OPEN LOOP FUELLING Parameter Menu.
We now give you ability to control your injector scaling, primary rev limit, open loop tps threshold, MAF Overboost threshold (previously available) and MAP based Fuel Cut for those who are using an External Map Sensor.
Some of the other changes that have been made are the Utec to ecu timing and vice versa interpolation. This will smooth out the drive ability considerably. The map calibration glitch has been fixed as well.
It should be noted that our base maps with this software will seem to be very conservative in our AFR. The base map is targeted for 11.1 AFR and the Timing Emulates the stock ecu's timing curve, slightly more aggressive.
Thanks,
Jermaine@turboxs.com
www.turboxs.com
Old Sep 22, 2004 | 07:01 AM
MalibuJack's Avatar
One word.. WOOHOO..
Old Sep 22, 2004 | 07:10 AM
MalibuJack's Avatar
Oh.. You might want to document in the updated manual how the Map sensor Mapping reference feature works, and the ABC's recommended setting (one or two turns out) if you choose to use it with closed loop boost.
Old Sep 22, 2004 | 07:17 AM
dktop's Avatar
Oh my god! is it comming??????
Can't wait!! ^0^
Old Sep 22, 2004 | 07:18 AM
Evo8M3's Avatar
Yes!.........AND its my b-day in one month exactly! There is no doubt I am gettinng this one!
Old Sep 22, 2004 | 07:23 AM
ArchieBabes's Avatar
Are you also gonna have downloadble maps for the staged upgrades? For us who has cams, bigger injectors and bigger intercooler upgrade and stuff?
Thanks
Old Sep 22, 2004 | 07:46 AM
dktop's Avatar
yeah~ jack.. good point.s
I am having very trouble with Ext. sensor installtion. weak manual of this thing.
Old Sep 22, 2004 | 07:48 AM
instigator's Avatar
So hopefully they can get the manual updated today. I really need to retune the car and I'd rather do it with. V1.6.
Old Sep 22, 2004 | 07:49 AM
Hatorade's Avatar
Ha ha, talk about good timing. I just put my UTEC in last week.
Old Sep 22, 2004 | 08:09 AM
Reignman's Avatar
TurboXS, you guys rock!! Cant wait to upgrade and tune with all the new features.
Old Sep 22, 2004 | 12:06 PM
SubiEvolved's Avatar
Old Sep 22, 2004 | 12:24 PM
PPI's Avatar
PPI
Great news for sure....will be putting in the cams , sprockets, and headstuds this weekend.
Old Sep 22, 2004 | 01:47 PM
TampaTurbo's Avatar
cool, I can dload a map and look at it. hahahah
Old Sep 22, 2004 | 02:24 PM
areet's Avatar
Yay, perfect timing because my Utec comes in Friday. That will give me enough time to play with maps, then make a nice one for 1.6. Question, will the 1.6 read 1.3's maps without a problem (assuming closed loop fueling).
Old Sep 22, 2004 | 02:28 PM
midwestmonster's Avatar
Right hurrrr!
