Supertech springs/retainers combo clearance!! $299 shipped
Super tech valve springs/retainers clearance: $299 shipped
Supertech valve springs:
SuperTech valve springs are stiffer springs specifically designed for use with aftermarket camshafts. As valve train dynamics change with the use of high performance cam profiles and greater lift, stiffer valve springs are needed to optimize valve movement. When changing to a high lift cam, stock springs cannot match the increased valve train movement. Therefore SuperTech engineered valve springs that are precisely matched to the characteristics of any aftermarket camshafts.
Supertech Ti retainers:
The role of a retainer is a stopper for valve springs. Therefore a retainer needs to be extremely strong and lightweight for reliability and engine response. The SuperTech Titanium Valve Retainer has been developed with emphasis on both strength and weight in mind. The SuperTech Titanium Retainer is 40% less weight than a stock retainer and twice as strong. As a result by using the SuperTech Titanium Retainer, the follow up response to the valve spring improves at higher rpm's.
Free shipping to lower 48 states
CA tax apply to CA residents
Thanks,
Tom
Thanks,
Tom
quick question. how hard are these to put in and is there any directions for the install? I've already installed cams and now I'm gonna put my headstuds in so I figured I might as well do these at the same time.
Its single springs and you will need a special tool to install it. If you don't have the tool, you will need to take off the head and bring it to a machine shop.
Thanks,
Tom
Thanks,
Tom
