Gruppe-S Engineering - California [Visit Site]
HKS RS intake kits
Old Jul 24, 2003 | 10:49 AM
MrBubbler's Avatar
is it possible to get kit without that cheap *** foam filter like maybe one of hks's filters instead, those filters dont protect anything as seen my some test run by people on this sight and the filters deteriorate over time and i dont want yellow foam in my engine =X
Old Jul 24, 2003 | 11:22 AM
Gruppe-S's Avatar
Hi guys,
HKS makes replacement filter elements in other colors as well. Unfortunately they are all the same thickness.
Thanks
Mike
Old Jul 24, 2003 | 01:02 PM
sanjaya1's Avatar
Does that come with a heat shield? I always thought that cone filters had a problem with sucking in hot air when the engine gets heated up.
Old Jul 24, 2003 | 04:16 PM
Gruppe-S's Avatar
Sanjaya1--It does not come with a heat shield. Some companies prefer to use normal intakes rather than CAI's on turbo cars, as CAI's don't dramatically help much on turboed cars. Also, because of the intake placements on EVO's a CAI will not help much.
Thanks
Mike
Old Jul 25, 2003 | 10:29 AM
MrBubbler's Avatar
how about no filter element and a actual filter i know they make it can u get it? i feel like ur not responding to me , i feel left out = ( maybe boost solutions can help me
Old Jul 25, 2003 | 10:55 AM
Gruppe-S's Avatar
mrbubbler--Sorry about that. HKS makes the supermega flow, the racing suction, and normal drop in filters. I'm assuming your talking about the drop in filters into your stock air box? Because the supermega flow and the racing suction both use the thin filter elements that you speak of. However, the drop in filters are also made of the same foam material. They also make a metal flow filter which is similar to the blitz sus intake kit. If you can please post a pic of which one you are looking for.
Thanks
Mike
Old Jul 25, 2003 | 02:09 PM
MrBubbler's Avatar
i guess what i want cant be done then but thanks for finaly replying , i will be doing buisness with you in the future since i no longer buy from vivid. cheers!
Old Jul 25, 2003 | 02:31 PM
Gruppe-S's Avatar
mrbubbler--From what you were describing you'd prolly want to go with the metal flow intake. It is just the intake itself that bolts onto the stock arm. Here's a pic
These would go for $200 shipped
Thanks
Mike
Old Aug 7, 2003 | 10:46 AM
Gruppe-S's Avatar
Intakes are back in stock guys.
Thanks
Mike
mike@gruppe-s.com
Old Aug 7, 2003 | 03:25 PM
Gruppe-S's Avatar
1 more left, thats was quick.
Mike
mike@gruppe-s.com
Old Aug 8, 2003 | 07:19 PM
DB8GSR's Avatar
thanks mike!
Old Aug 8, 2003 | 11:00 PM
EvO-STaTS's Avatar
Mike. Im interested in the hks intake, but i have a question i would like to ask you first. Does the intake have an opening for a recirculating bov?. I can see from the picture above something that looks like a stock bov connected to the intake. I just wanted to be sure before i buy.
Thx in advance STaTS.
Old Aug 9, 2003 | 08:22 AM
lancealott's Avatar
Is there a projected time period of how long you can use this filter to avoid having it fall apart in the engine. I was really interested in this until I heard of the filter falling apart. Also, how much is a new filter?
Old Aug 12, 2003 | 10:57 AM
Gruppe-S's Avatar
evo-stats--The intake pipe on the RS intake has the same connections as the stock pipe, so yes you will be able to connect the recirc valve into this intake. Thanks
lancealott--I've never heard of the elements falling apart and being sucked into the intake system. As with other air filters, these elements should be changed on a regular maintanence schedule. HKS recommends every 20,000 or so. Extra filter elements run $15 each.
Thanks
Mike
Old Aug 12, 2003 | 11:04 AM
TURBODAWG's Avatar
Do you have any left?
Brian
