Serious Power Mods-Injector Combo $449-Forge Mount Inserts $199-Okada Projects $399
Happy Holidays everyone! we got some great items just in time for Christmas. The awesome Okada Projects Coil Packs are back in stock! Dont forget to check out the all new Forge Motorsports engine mounts inserts a great upgrade for a few bucks.
Okada Project Coil Packs
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines
$399 Shipped
AEM Water / Alcohol Injection Kit
AEM’s Water / Alcohol Injection Kit reduces air inlet temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
$375 Shipped
Cusco Turbo Inlet Pipe
$299 Shipped
Injen
Intake/ Intercooler Pipe Kit $350 Shipped
Intercooler Pipe Kit $299 Shipped
ARC
Induction Box $375 Shipped
Titanium Intercooler Piping $849
BOV
EVO MR DV Kit $99 Shipped
Type RS $230 Shipped
HKS SSQV BOV ver2 Kit $345 Shipped
GREDDY BOV Type RS Kit $239 Shipped
Blitz DD BOV Kit $249 Shipped
GFB Stealth BOV Kit $299
Helix Fuel Combo
Helix 720cc Injectors w/ Walbro 255 $449 Shipped
Forge Engine Mount Inserts
The bushing is made from polyurethane as opposed to the OEM rubber bushing material which is much softer. The kit comes supplied with a specific stainless steel sleeve and a packet of copper grease/anti-seize. It is a direct replacement for the soft OEM front mount bushing and fits with absolutely no modification. Installation takes about 20 minutes. The most difficult part is removing the factory bushing from the mount which basically needs destroying to get it out, but once accomplished, the Powerflex bushing fits in easily. After installation you should notice an immediate improvement in shifter feel and on/off throttle vehicle response due to significantly reduced front-to-back movement of the engine under on/off throttle conditions. The car should seem to "buck" less under light throttle cruising, and much less engine movement during the disengagement of the clutch under light throttle. There is a very slight amount of increased vibration at idle only, which is to be expected, however this additional vibration is only felt through the steering wheel to the driver, your passengers would never know that you changed anything if you didn't tell them what you did. This vibration is so minor that it would not be worth mentioning it but I am sure that many owners would ask the question before committing to this install. It is also usual for this initial increase in vibration will go away after a short period of time (a couple weeks) once the bushing settles in.
$199 Shipped
$399 Shipped
$375 Shipped
$299 Shipped
Injen
ARC
BOV
Helix Fuel Combo
$199 Shipped
