Turbo Fuel Injectors????
Old Nov 9, 2004 | 11:18 AM
krnzzang84720's Avatar
How come TSI's turbo kit only comes with only two fuel injectors???
should we get four??? or is there reason for that???
Old Nov 9, 2004 | 11:56 AM
HobieKopek's Avatar
Have you tried asking TSI or one of their resellers? You're likely to get a faster response that way.
Old Nov 9, 2004 | 04:40 PM
acs_guitars's Avatar
I believe they are meant to be used by mounting them on the intake manifold, kind of like a wet shot nitrous. So you would have 6 injectors, the 2 extarnal ones with the TSI will provide the added fuel during peak boost. Some one correct me if I am wrong.
Old Nov 9, 2004 | 05:05 PM
HobieKopek's Avatar
I would presume so, but generally one very large injector is easier to use than two. Contactnig TSI would probably be the easiest way to find out HOW they build their fuel system.
Old Nov 9, 2004 | 08:20 PM
.L.'s Avatar
.L.
correct. both the extreme and superior kit use your stock injectors. same thing with my buddy's honda kit. i think there is an option to upgrade the "fuel components" but its more $$$$.
Old Nov 10, 2004 | 01:19 AM
hmm that is why!!! how about just getting bigger injectors!!! like RIPPMODS's ??
Old Nov 10, 2004 | 10:09 AM
.L.'s Avatar
.L.
^ you probably dont need them to run the basic kit. if you plan to up the boost in the future, then you'll probably need upgraded fuel injectors. they probably do it so they can offer the kit a bit cheaper also.
