I need help with fuel injectors
RC injectors are great, albeit slightly expensive. Just make sure that you get the high impedance ones. The low impedance ones are in abundance everywhere, but eventually, unless you get a resistor pack, that wrong impedance signal will start sending things haywire. Brand new, they can cost a pretty penny; that's why I opted with the RX-7 ones... pretty expensive but still cheaper than RC and they were also cleaned and flow tested from the shop I got them from.
Non STI 440's should work fine. This is a new thing for the average eclipse driver planning for boost. I personally am using evo 560's but cant find a stright answer on if or what kind of resistor pack i need. I got one off of eby from a 1g eclipse for 450's but not sure if its sufficient for evo 560's. Do evos have resistor packs as well??
WTB[MidWest]: WTB: Stock Injector
auni93085
Oct 12, 2015 09:25 AM
