Oil Leak
Old Oct 13, 2005 | 04:24 PM
mitch44759's Avatar
Question Oil Leak
Hey Guys
I finally finished my turbo install but i have a small problem the little black oil pan is leaking through what appears to be the screws I sealed it with peratex same stuff i sealed the main oil pan with which is not leaking. What should i use to seal the small pan.
Old Oct 13, 2005 | 04:32 PM
imapunkclaimer's Avatar
you may have bent the lower pan when you were taking it off if you used a screw driver. look by where you pryed it and see if anything is coming from there. i used blue sealant first, but then later after i resealed it i used gray and havent had a drop of oil since.
Old Oct 13, 2005 | 04:34 PM
mitch44759's Avatar
checked it for damage before i put it back on, there was none
Old Oct 14, 2005 | 09:23 AM
AznFlip's Avatar
You need a new upper oil pan, so buy mine! lol
Old Oct 14, 2005 | 11:43 AM
mitch44759's Avatar
I would if the upper oil pan was the problem but nice try. I did find out that mitsubishi uses ultra gray to seal, so i am going to try that.
