Cat Questions For The Turbo Guys
Old Dec 1, 2005 | 07:13 PM
yellowlancerOz's Avatar
Are you guys running stock cat? Im in the works of removing it b/c FL we dont have emission and i can get away with it. I was planning on cutting it out and welding a piece of stainless steel on there or the other option was to get the high flow cat or the test pipe?
What have you guys done and what are your expierences?
Old Dec 1, 2005 | 07:18 PM
ozrally0303's Avatar
must be nice to not have emssions just get the test pipe its cheap nicely made and fits perfect
Old Dec 1, 2005 | 07:20 PM
how does it sound with the greddy exhaust...i have the same exhaust
Old Dec 1, 2005 | 07:22 PM
also how big is the pipping on it?
Old Dec 1, 2005 | 08:26 PM
Blacksheepdj's Avatar
Just get a test pipe. It's easy and it works great.
Old Dec 1, 2005 | 08:29 PM
sweet_bucket22's Avatar
yeah test pipe or if that's to loud a highflow cat. I've seen many like the HFC's as they give you some more low end torque.
Old Dec 1, 2005 | 11:16 PM
N1te's Avatar
if u want a homemade high-flow cat and they don't have emissions in your state you can remove your stock catalytic converter and do a little bit of... porting on it (handle end of a hammer.) and make your own high-flow cat. be adviced though, you will then have no replacement cat. and a test pipe/high flow is definately cheaper than a stock catalytic converter.
Old Dec 2, 2005 | 09:10 AM
mitsulancerrace's Avatar
one of my friends used a HUGE 2" drill bit and drilled it out. cuz in NY they look to see if its there and whatnot, so it looked like it was there, but it prettymuch wasnt
Old Dec 2, 2005 | 11:23 AM
i think im just going to buy a piece of stainless steel pipping and cut the cat out and weld the piece in....i have the tools and the knowledge to weld......do you guys know the size of pipe at the end of the cat?
Old Dec 2, 2005 | 10:15 PM
CNFX1's Avatar
You'll probably pick up 10 hp just from getting rid of your cat on a turbo car.
Old Dec 3, 2005 | 11:51 AM
bahamut's Avatar
Carlos,
Are you sure that you want to do it? You might get a CEL and be forever in limp mode.
Also, if you get the wrong material or length of the tube, you'll get horrible noise coming from it. Greddy naturally sounds good . . . now, you'll amplified the noise level. It can vary as much as the sterotypical weedwhacker or bumblebee sound like some stereotypical H&A products or sounds like an old muffler that needs to be replaced. Remember, the more noise = more attention from thugs and cops.
Besides, the HP that you'll gain is negligible, unless w/ some tuning.
Old Dec 3, 2005 | 12:19 PM
just get rrm test pipe direct fit how much easyer can it be except getting those cat bolts off are a ***** i had to grind mine off and drill them out
Old Dec 3, 2005 | 12:44 PM
HobieKopek's Avatar
I'm never a person to advocate the use of test pipes. High flow cats are a much better way to go IMO. Less CO, less NOX, less unburned fuel coming out your exhaust. HP differences are negligable.
Old Dec 3, 2005 | 11:49 PM
david,
how are things going....i know it is going to be louder...just feel it is restricting me though....also everyone hates driving behind me b/c it smells so bad they say
i might just go with the high flow cat then.
Old Dec 4, 2005 | 08:06 AM
bahamut's Avatar
I'm somewhat okay, just tons of stress.
You have turbo, now? Otherwise, you just need some tuning. Did you talk to Cory, djphatrock? He's was in a similar situation as you but NA w/ backfiring, running rich, and stuff.
