3 random turbo questions
Old May 3, 2006 | 12:28 AM
Go_Lancer_Go's Avatar
1. w/ spark plugs(colder ones of course) w/ a turbo kit, how much do u have to gap em?
2. how do u know if ur walbro fuel pump is going
3. if ur driving, not under boost and notice a lil hesitation once in a while and when this hesitation hits ur AFR goes to like 13 or 15(when normally it stays in the 14's) is that a problem w/
- spark plugs
- fuel injector a lil clogged
- ecu piggyback map (emanage)
Old May 3, 2006 | 05:14 AM
Silens's Avatar
1. mine are at .030 as per RRM instructions
2. if your car runs, and you can hear it, (it is a very anoying whining sound) then it should be working
3. just drive wot all the time you wont notice it j/k i dont know never noticed anything like that on my car.... yet, hopefully i wont, but anyways imo sounds like piggy, emanage whatever your using, you might need to check the fuel map around the area where youre having that "hesitation", but im no expert on that so hopefully somebody posts up something more helpful
